Interesting idea... possible 10HP firebird gain?
Old Jun 19, 2008 | 12:44 PM
TPImoneypit's Avatar
Ok, so I know that TPI Camaros have 10 HP stock over Firebirds due to the 'bird's intake location. Now, is it possible to retrofit a Firebird to have the same dual-filter intake setup as a Camaro? Anyone ever tried this? I figure if that's the separation between the two and makes the difference in HP, it'd be a pretty sweet mod.
Old Jun 19, 2008 | 12:55 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Interesting idea... possible 10HP firebird gain?
No need to. You can easily make a custom CAI for the Firebirds that will out flow the Camaro style intake system.
Old Jun 19, 2008 | 05:18 PM
Russ-So Cal's Avatar
Dyno Don on this board has built an intake for his 1990 T/A using 3.5 inch tubing with mandrel bends from a K & N filter located in the cold air below the stock filter location into his plenum following the same path as stock. It will out flow anything stock from the factory on either model
Old Jul 1, 2008 | 11:55 PM
87transGTA's Avatar
Car: 87 GTA
Engine: 350 Tune port
Transmission: 700r4,2500 stall
u know where the thread is for it id like to see how he did that i could really use an intake
colton_carlson
Mar 8, 2019 12:21 PM
Scamo-2.8
May 20, 2016 07:01 PM
Poncho92
Group Purchases
Aug 25, 2015 02:17 PM
Dialed_In
Aug 20, 2015 01:45 PM
Poncho92
Aug 7, 2015 08:15 PM
