volts with nos
Old Dec 8, 2001 | 09:39 PM
my89formula350's Avatar
volts with nos
hi guys what should my mV reading be for nos any help would be great
Old Dec 8, 2001 | 10:13 PM
Desert86Roc's Avatar
Your 02 readings will be much higher running NOS as the mixture is much richer to prevent detonation. There is no desired mV that you are looking for...just make sure your fuel pressure, NOS and Fuel jets all match up to recommended levels. If you talk to your NOS manufacturer, they can recommend which jet sizes to use when you have greater than stock fuel pressures.
Mike Metzler (Desert86Roc)[*] Check Out:SpeedWorldMotorplex.com[*] Check Out:Chevrolet F-Body Online Part & Illustration Manual[*] www.MetzlerRacing.com
Best ET @ 1250 ft[*] 15.352 @ 91.215 mph (uncorrected)
RS Reaper
Oct 17, 2018 07:52 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
