does anyone know the torque specs on intake??
Old Dec 7, 2001 | 04:28 PM
SS-IROC-Z's Avatar
i need to know the torque specs on a 87 350 TPI intake?And does any one know how many relays there are for TPI motor i am using a 87 TPI System.And does any one know where i can find pics on where the line that goes from EGR valve goes to? And is there Specs for Flywheel?Thanks i hope u can help with my motor swap I am putting 350 TPI into 87 SS.
Old Dec 7, 2001 | 04:35 PM
vortech305's Avatar
20 ft lbs
Old Dec 7, 2001 | 06:03 PM
rezinn's Avatar
Are you sure, vortech? I thought it was between 30-45ft/lbs.
Old Dec 7, 2001 | 08:45 PM
Free Bird's Avatar
Car: 91 GTA and 85 IROC
Engine: 355
Transmission: gear jammer
Axle/Gears: 4.11
I go 20 on the plenum and 35-45 on the base.
Old Dec 7, 2001 | 09:06 PM
rezinn's Avatar
Alright.. I never really torque the upper intake, I just make it snug. The lower intake should be higher than 20ft/lbs though, in case thats what you were talking about.
Old Dec 9, 2001 | 01:36 PM
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
AFR recommends that the intake manifold bolts should be only "snugged" in sequence.
1991 Firebird
350 L98 (was a 305 TBI),T-5,Edelbrock TES and cat back,Accel manifold
NOS,subframes,jegster torque arm,MSD Digital 6
AFPR,Lakewood lcas
Hurst linelock,SLP cam (206 212 .480 .486),relocated battery,cold air,Hypertech chip,centerforce df,clutch
poly bushings and mounts
AFR 190s
Harland sharp 1.5 rockers
autopower rollbar
12.33 @ 114.83 juiced uncorrected
13.510 @ 102 non juiced uncorrected
Old Dec 9, 2001 | 05:17 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I go 42 on the intake and 18 on the plenum and runners.
Old Dec 9, 2001 | 05:33 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
GM says 35 ft/lbs on the lower intake, but what do they know about building F-bodies, right?
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
redmaroz
Apr 25, 2017 07:14 AM
deracer
Apr 11, 2016 12:04 AM
BAMiller
Sep 14, 2015 06:38 PM
theurge
Aug 21, 2015 12:46 PM
