Why do I get such crappy gas mileage????
Subscribe
Dec 4, 2001 | 10:07 PM
I've been trying to improve my gas mileage. On my last two full tanks, I had 12 mpg and 11 mpg. I did not go wide open throttle on either of those tanks, and I drove at normal speeds. It did not just start either. It's been crappy ever since I dropped in the 355. My mods are in the sig. I know I shouldn't expect great gas mileage, but everyone else is getting much better. Any suggestions on what to do? Fuel pressure is around 46-48 PSI. The O2 sensor is not reading rich either. ANY help would be greatly appreciated. Thanks.
1984 Camaro Sport Coupe - Rebuilt 355 S/D TPI L98, Crane 2032 CompuCam, Crane adjustable fuel pressure regulator, MSD Blaster coil, custom burned PROM, stock TPI intake, Accel 24# injectors, gutted air box with K&N filters
F41 Suspension Package, 700R4 Tranny, TCI Breakaway torque converter, 3.27 Posi Rear
Hooker Shorty Headers, Catco High-Flow 3" Cat, Flowmaster 3" American Thunder Cat-Back
JVC Head Unit, Kenwood Amp, Pioneer 4x6's and Pioneer 6x9's
Best 1/4 Mile Run:
13.847 @ 95.91 MPH
1992 1LE B4C Police Camaro RS - 305 TPI 5-Speed
Reply 0
Dec 5, 2001 | 07:55 AM
What type of driving do you do? Is it mostly city? Stop and go? Or do you actually get some cruise time in there?
I found that driving around the small town where I live, I get between 17-20 mpg, but, if I drive around in, say, cleveland, mileage drops to around 12.
My car is a basically stock 88 formula 350, with a few of the bolt on mods, and an MSD ignition box.
Reply 0
Dec 5, 2001 | 04:05 PM
you wouldn't happen to be running a 160*° Thermostat? I hear that it might not let the car go into Closed loop, which is where your car should be the most efficient..
I could be wrong, but it makes sence...
John
G O D BLESS AMERICA
http://www.3rdgenformula.com
87 Formula 5.1 TPI Auto Modified (Yellow/Black)
87 Formula TPI (5 Speed) Yellow/Gray STOCK
14.8sec 1967 Buick Riviera
1990 Buick Riviera (driver)
83 Camaro
83 T/A
Reply 0
Dec 5, 2001 | 06:10 PM
I do not get very good mileage driving all city either, but I do get on it quite a bit.
Just check and see that it is getting into closed loop. hope this helps
14.48@93.72mph 2.03 60 ft
After Pulley's 14.31@95.18, 2.14 60 ft
Reply 0
Dec 5, 2001 | 06:49 PM
I am running a stock thermostat (195 I believe) and it is going into closed loop. I checked with my dad's scanner. Thanks for the replies. Any other ideas?
Best 1/4 Mile Run:
13.847 @ 95.91 MPH
Reply 0
Dec 5, 2001 | 10:39 PM
what are:
park idle: MAP kPa/v, tps v, O2 v, block learn/fuel integrator
park drive: MAP kPa/v, tps v, O2 v, block learn/fuel integrator
2000rpm cruise: MAP kPa/v, tps v, O2 v, block learn/fuel integrator
3000rpm cruise: MAP kPa/v, tps v, O2 v, block learn/fuel integrator
4000rpm cruise: MAP kPa/v, tps v, O2 v, block learn/fuel integrator
the 3000 and 4000rpm redings can be in second gear
as local law authorities frown on high-speed
neighborhood passes.
a passenger taking readings while testing would
be best.
why so much fuel pressure?
your custom chip was before or after the new engine
and add-ons??
airdeano
[This message has been edited by airdeano (edited December 05, 2001).]
Reply 0
Dec 10, 2001 | 03:57 AM
Might want to look at the misc. stuff like tire alignment, tire pressure, replace the wheel bearings or at least clean out the old grease.
Reply 0
Subscribe
