Code 33
Old Dec 10, 2001 | 07:35 PM
HotRod's Avatar
Car: 87 GTA
Engine: Eaton Supercharged 350 TPI
Code 33
I just checked to see what was causing a code 33 on my 87 gta with 350 TPI. Do I have a bad MAF sensor or could it be something else? How do I check to see if the Maf is bad? Thanks
Old Dec 11, 2001 | 05:29 AM
rezinn's Avatar
Check to make sure the sensor is sealing well, since that code means low vaccuum. Try disconnecting the sensor to see if the car runs better. I've gone through three remanufactured sensors in the past two years until I got one that stayed working.
Old Dec 11, 2001 | 09:00 AM
TC602's Avatar
Car: 86 IROC
Engine: ZZ4
Transmission: T5 WC
Also check the relays on the drivers side firewall. There are three relays there, but only two are for the MAF. One is the MAF realay the other is the burnoff relay. Also ckeck you connection at the MAF, make sure it's plugged in right.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
