TPIS Big Mouth Base
Old Dec 9, 2001 | 12:11 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
TPIS Big Mouth Base
What makes this base so special, and why is it called a big mouth base. I am sitting here comparing it to my stock base and the intake ports measure the same size, so do the runner openings. Whats up with that, and also it doesn't look like it has all this extra room for porting over the stock base.
Am I missing something here
Old Dec 9, 2001 | 10:37 PM
David 91RS/Z28's Avatar
Either your on crack or you just got ripped off! The TPIS base is so much larger than stock! How can you not tell the difference? If your base doesn't have TPIS cast into it, then it's a stocker. Don't take this the wrong way, I just can't believe you can't tell the difference!
David Tuschhoff
1991 RS/Z28 Camaro
FI 355ci NA SBC V8 M5.
12.47 @ 110.7mph 1.80 60'
Best mph of 111.6.
My f-body page!
Old Dec 9, 2001 | 10:59 PM
Car: 1992 Camaro
Engine: 350 miniram
I am pretty sure I am not smoking crack. The intake is for sure a TPIS and it is cast into the base. I also have a stock one as well that has GM cast into it. What I am saying is that when I measured the intake and runner port openings they are the same dimentions as the stock base. It seems inside that it opens up and has a larger volume, but the ports aren't any bigger.
If I am wrong about this, I would be interested in knowing what the dimentions of the intake and runner ports are for both the stock and TPIS intake
Old Dec 10, 2001 | 08:43 AM
blak92!'s Avatar
The ports are THE SAME SIZE because the base is casted for the STOCK heads. They WOULD HAVE MADE THE PORTS LARGER if you had asked them, or told them what type of aftermarket heads you are using. Also, the base runners are at a more direct angle to deliver air from the intake runners, through the baserunners, to the heads.
Hybrid Black 5.7L 5 Speed
'95 Competition Yellow Corvette Coupe ZF6
Old Dec 10, 2001 | 05:40 PM
Credit goes to Mike Davis on this information. He is using the Edelbrock base, but it's the same as the TPIS base(except TPIS port matches the runners to a 1205 intake gasket, or at least they did on mine).
Stock base....
http://www.eecis.udel.edu/~davis/z28...akebase/stock/
Edelbrock base....
http://www.eecis.udel.edu/~davis/z28...up/intakebase/
You can clearly see the difference! The runners are full size all the way through. HTH!
David Tuschhoff
1991 RS/Z28 Camaro
Best mph of 111.6.
My f-body page!
Old Dec 11, 2001 | 09:12 AM
Car: 1992 Camaro
Engine: 350 miniram
Thanks for the link, it answered all my questions.
Keith5
Aug 27, 2015 04:37 PM
bdads
Aug 24, 2015 06:01 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
