TBI to TPI nightmare...... electrical problems
Old Dec 11, 2001 | 02:08 AM
Realm287's Avatar
I spent thousands of dollars to build a 383 with forged everything, and I put a used TPI system on top of it with the TPI computer and Harness and it will not start, the injectors are not injecting and the distributer does not create spark unless I use a dummy wire, does anyone know what could be wrong with my setup? could it be the computer? if so how can I have this checked? if not the computer what else could it be.
Also I do not have a lot of stuff hooked up like all of the emmissions accessories. Emmissions tests not required where I live. Could this be affecting the lack of power to the injectors and distributer
Someone please help.....
Mechanical is easy Electrical Sucks
Old Dec 11, 2001 | 03:19 PM
afgun's Avatar
Car: Non F-body :(
Engine: Pontiac 301
Transmission: TH350
Try and get a FSM for your year of TPI.
There's lots of good tests. First you need to make sure you have power to the distributor. If you have that, then you need to make sure the distributor is delivering reference pulses. If it is, then the problem is in the computer or injector wiring.
The manual has extensive testing procedures for figuring out what's wrong.
MustangBeater20
Oct 29, 2022 09:20 PM
Sanjay
Aug 12, 2015 03:41 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
