code 32 0n 91 5.7 tpi
Old Jun 23, 2008 | 12:38 AM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
here is the deal on warm cruise the egr is coming on hard causing the car to surge and will stall at lites check engine comes on disable the egr and it runs good. my car is a conversion running a 91 speed density harness and everything is 91 {sensors,modules,etc}. i made the vac lines and have the egr supply hooked to the port at the botto of the throttle body. i know the valve is good and all sensors and engine parts are new. is my egr control solenoid the problem??. i tried to get a new one but it is not availble from any parts supplier i could locate thinking of modding a tbi unit to fit.
thanks
luke
Old Jun 23, 2008 | 01:21 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: code 32 0n 91 5.7 tpi
3 things come to mind, the solenoid could be sticking, the vent port is clogged, or you have the lines on the solenoid hooked up wrong.
when the ECM turns the solenoid off, it should bleed the vacuum off right away. you can Tee a vacuum gage into the line between the solenoid & valve & see if it holds vacuum when you let off the throttle.
but with the vacuum lines hooked up right a problem with the solenoid is really the only thing that makes sense.
using a solenoid from a TBI system should work just fine.
Old Jun 24, 2008 | 12:24 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
No, a TBI solenoid and a TPI solenoid are backwards. One is normally open and the other is normally closed, but I dont remember which is which.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
Lmancha96
Sep 25, 2015 08:11 PM
Racerx974
Sep 19, 2015 10:16 AM
