An Injector cleaner
Old Dec 11, 2001 | 05:30 PM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
An Injector cleaner
Not talking about the cleaners you put in your gas take. I'm looking for the type of hook up that would go on an injector that is off the car. I've seen the ones that go on the car, but is there any that goes on just the injector. If so, how much for this and where could I get it?
Thanks.
91 Z28
Best Time Slip:
60' - 2.098
1/8 - 9.137 , MPH - 76.21
1/4 - 14.213, MPH - 97.55
Performace Mods: SLP Catback
Appearance Mods: SS wheels, 2.5" Cowl Hood (not on at the moment), Clear Side Marker Lights
ICQ: 1437212
AOL: normalmatt9
More Pictures are Here
Old Dec 11, 2001 | 06:07 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
We do this alot at work. We don't actually remove the injector, but we hook a pressurized canister up to the fuel rail, disable the fuel pump, and set the pressure BELOW the FPR's setting so it doesn't bleed off into the tank. Then we run the car strictly off the cleaner. We use GM's approved cleaner, gasoline w/ a 10% mix of Top Engine Cleaner. Works excellent.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 11, 2001 | 06:51 PM
Ions91Z28's Avatar
Would thier be a tool that could possibly do that off the car? Bascially, it's just some time of carbon/gunk type build up in there correct? Seems as though a pressurized cleaner would be able to do it. Just don't have any tools or know where to get them.
Thanks.
91 Z28
Best Time Slip:
60' - 2.098
ICQ: 1437212
AOL: normalmatt9
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
92-Formula
Dec 12, 2015 10:34 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
edoff13
Sep 11, 2015 03:55 AM
