RPM top end power advice
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: RPM top end power advice
Is the LB9 the 305? If yes, I would buy the large tube runners, and do some porting to the plenum and base. With the factory heads, I would just port the exhaust manifolds until I could get aluminum heads, then go with 1-5/8 tubular headers.
To answer your question directly, I have to say both. You got to get more air in, and you got to get it out! Sorry I am not of more help.
The right side exhaust manifold narrows down to 1 inch inside diameter right ath the back where it bends down to got to the wye pipe. There is nothing you can do to open it up. Go with exhaust upgrades first.
theshackle
Sep 17, 2020 08:26 AM
