no spark when rpm is around 3000-3500 HELP!!!
Hey, I have a 88 305 tpi f code motor. When it gets to about 3500 rpms it cuts out (checked spark none when it cuts out) It will start right back up. I just took the smog pump off and put in new injectors in. Seamed like it started after this. It also sends out a code 42 what to try first???
ignition modual? or maybe weak coil?
does it have no spark anywhere past around 3500? if so then i would think it is a bad ignition modual, they have a high and low RPM type function. you can have it tested at some auto parts stores
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited December 09, 2001).]
- David
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
If you get a module dont get a 20.00 wells part. My car ran like crap on the topend with the wells the stock one was better. Get a Holley or Accel module if you replace it. My car runs better all around with the Holley module. The topend was the most noticable improvement My car would cut out around 2500/3300 and miss at 5000+ rpm with the new Wells part.
90 IROC
SuperRamed 406
Trickflow 23* heads
90 IROC
SuperRamed 406
Trickflow 23* heads
hey thanks for sending me in the right direction. It was the stupidest thing! one of the prongs on the 4 prong plug on the module was bent. Fixed the plug and the car runs better then ever.
THANKS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
MikkoV
Sep 9, 2015 04:25 PM
