LT1 conversion update: Ran into problems
Old Dec 21, 2001 | 02:16 PM
  #51
RCR's Avatar
RCR
Car: '84 Fiero ('01 GA interior)
Engine: '96 4.0 Aurora
Transmission: '96 4T80E
Omega: Yep.
89 IROC Z: 350 GM crate, LT4 HC, ported plenum & siamesed SLP runners, ported stock base, 24lb inj, DFI, TFS TWG1 heads,...etc
Old Feb 7, 2002 | 03:50 PM
  #52
GofasterFirebird's Avatar
Car: 1991 Firebird
Engine: 427 LSX
Transmission: Turbo 400
Anyone use a wet N20 plate system with this manifold swap? If not, can anyone forsee clearance issues?
Old Mar 20, 2002 | 04:15 PM
  #53
DURTYBIRD's Avatar
Car: '99 HO Z28 / '03 Trailblazer
Originally posted by RCR
With the only difference being the intake, I tested at 272 rwhp and 307 ftlbs of torque. I don't have the curve with me, but I think I topped out at 5300RPM. I just hope I have a chance to get the tuning in. I'll kerep you updated...
TTT... any results for us? I can't wait to get started on this. I have the intake and have ordered the fuel lines. Holly AFPR on it's way too...
Old Mar 20, 2002 | 04:31 PM
  #54
camaro6spd's Avatar
This is an INTAKE SWAP not a LT1 SWAP
I see theses postes....It is the LT1 intake not the whole engine....please specify that next time in the topic. thanks
Old Mar 20, 2002 | 04:32 PM
  #55
camaro6spd's Avatar
Re: This is an INTAKE SWAP not a LT1 SWAP
Originally posted by camaro6spd
I see these posts and come in here looking for an LT1 Engine swap....It is the LT1 intake not the whole engine....please specify that next time in the topic. thanks
Old Mar 20, 2002 | 07:12 PM
  #56
DURTYBIRD's Avatar
Original post was by RCR who is listed as a moderator...
Old Mar 23, 2002 | 06:52 PM
  #57
DURTYBIRD's Avatar
ttt... I'm curious since I am doing the same mod (starting the intake mods this weekend...
Old Mar 28, 2002 | 12:31 PM
  #58
DURTYBIRD's Avatar
Old Mar 28, 2002 | 02:28 PM
  #59
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's a reason that the message boards have a "message" field instead of just typing your whole message into the title. 10 seconds of reading will clear up your problems!
Old Mar 29, 2002 | 09:54 AM
  #60
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
has anyone thought about going through the front of the head into the water jacket?just in theory it seems that you may be able to drill and tap for a 90* fitting(3/8) and bend s/s lines behind the accessories(may have to space accessories forward a little)then you may be able to hide the remote t-stat housing under the intake elbow onlu thing is getting the upper radiator hoseto bend under there for a clean install.:lala:
Old Mar 30, 2002 | 11:31 AM
  #61
RCR's Avatar
RCR
Camaro6spd: Picky picky...If you want info on engine swap, check motor swap board... BTW, why was this dredged up from December? Too much has happened since then...
Old Apr 1, 2002 | 07:35 PM
  #62
DURTYBIRD's Avatar
Well, is there a more current thread? I searched and found nothing.
I am in the midst of modifying the intake manifold and will be aiming for install within the next month. I had hoped that you may be able to shed some light on any other 'developments' you encountered along the way - possibly any other feedback you could give me on the outcome. It's my daily driver so I am hoping for as little downtime as possible.
Thanks!
Old Apr 2, 2002 | 06:50 AM
  #63
RCR's Avatar
RCR
You've got mail...
Old Apr 2, 2002 | 08:12 AM
  #64
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
RCR:
Can you also send me the updates
midge54
Dec 27, 2019 04:14 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 17, 2015 02:52 PM
sreZ28
Aug 14, 2015 07:48 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
