Oil sending unit?
Old Dec 13, 2001 | 09:51 PM
FatOne's Avatar
Oil sending unit?
Will the eng of the car be F-up. If the oil sending unit is bad and whas not changed for about 8,000 miles?
Old Dec 13, 2001 | 09:55 PM
breathment's Avatar
ok, so ur asking if there will be any engine damage from a bad oil pressure sending unit?
or the oil pump?
if its the pressure sending unit NO, as long as it wasn't leaking and u leaked all ur oil out
most of the stock sending units don't work that good anyways. you could go forever without it working.
oil pump, then i don't think the car would last 8000 miles.
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake, and an Energy Suspension Poly trans mount that is worse then the broken rubber tranny mount
http://www.geocities.com/david_angel_16
[This message has been edited by breathment (edited December 13, 2001).]
Hotrodboba400
Dec 10, 2019 07:07 PM
Gunsbee
Sep 7, 2015 07:10 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
