Car acts like its missing.
Old Dec 14, 2001 | 01:16 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
My borther has an 89 IROC, 305, auto, and the car runs like it is missing. We've checked the wires(replaced), checked the plugs(replaced), checked fuel pressure(40psi), and replaced the fuel filter. Nothing seems to help. If we start the car it runs like it's not firing on 1 cyclinder but everything looks like it's running like normal. If he drives the car eventually will die but will start back up.
Any suggestions at this point would be appreciated. Thanks.
'91 Z-28 5.7, SLP 1 3/4 headers, 4 inch Mufflex/Flowmaster cat back, gutted cats, Edelbrock intake, 8.5mm Jacob wires, MSD Blaster coil, S&W subframe setup, Jacob Pro Street Ignition, complete Kenwood system.
Old Dec 18, 2001 | 01:38 PM
CraZ-28's Avatar
Car: 1991 Z-28
Nevermind....figured it out.
Old Dec 18, 2001 | 01:47 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
Well, what was the fix ?
Old Dec 18, 2001 | 02:02 PM
CraZ-28's Avatar
Car: 1991 Z-28
2 bad injectors. I ran ohm readings and #3 was at 8 ohms and 5 was at 1. After replacing #5, the car ran 200% better. Will be replacing #3 in a week.
Old Dec 18, 2001 | 09:59 PM
Tony86TA's Avatar
Had the same problem awhile back. Sure enough a couple bad wires going to #4 injector! Felt like I gained 50 hp+.
Ghettobird52
Jul 5, 2024 11:18 PM
hectre13
Dec 11, 2023 08:14 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
