Need a cam suggestion for MPG / Power
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
With fuel prices the way they are and only looking to get worse, I am looking at putting together a package that will get good mileage and make good power. I have no expectations on a horsepower goal, but I would hope to make 325-350 or so with a flat curve. I wish for a solid 25 mpg or so which I believe is entirely possible as I am getting 21 now with stock TBI 350 heads and a Summit 1103 cam. I am using this car as daily transportation, roughly 75 miles a day, providing the weather is good... The package that I am going to use is as follows:
Vehicle : 1957 Chevy, approx. 2900 lbs.
355 shortblock , balanced, hyper pistons
TPI, stock throttle body with an airfoil
Stock runners
Accel ported base
ported plenum
TPIS adj. regulator
Holley 24lb. injectors
long tube 1 3/4" headers, 3" collectors
Dual 2.5" exhaust
Pro Topline iron heads, 167 runners, 67cc chambers, 1.94/1.50 valves
Comp Cams 986-16 springs
Summit 1.6 ratio roller rockers
Built 700r4
3:55 rear
I know I am leaving something out here....
Anyways, can I get some input from you all? I appreciate the help !!!
Jason
Stock runners
Accel ported base
ported plenum
TPIS adj. regulator
Dual 2.5" exhaust
Built 700r4
3:55 rear
Jason
Car: 91' Camaro
Engine: 383 ci
Re: Need a cam suggestion for MPG / Power
Too aggressive and it won't match the TPI flows though.... I figured I would get a ton of responses with this.... Any input is appreciated.
Jason
Jason
Car: 88 GTA "Cocaine"
Engine: 350 tpi
you could not give me those head
unless I needed another set of wheel chauks
325-350 horse and 25mpg
go get a 350z
go get a 350z
Car: 91' Camaro
Engine: 383 ci
No, I don't need a 350Z, I will gladly drive my American car instead with more power and in the same ballpark for mileage.
Jason
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The XFI268HR-113 would be great in that combo. Or just put a ZZ4 cam in it.
Car: 91' Camaro
Engine: 383 ci
theshackle
Sep 17, 2020 08:26 AM
