Fuel Gauge
Old Jul 1, 2008 | 05:34 PM
Robb Knight's Avatar
Car: 1989 Firebird Formula 350 TPI
Engine: 5.7 350 TPI
Fuel Gauge
Ok Im trying to find out the name of the "thing" that goes in my gas tank that determines the level of fuel. In other words my gas tanks always says fuel and Im trying to find out the name of that sensor. Im told its in the tank and that thats my problem. I was told its called a "fuel level sensor", but I cant find anything under that name on any sites like Autozone.
Old Jul 1, 2008 | 05:56 PM
SmokinMyTires's Avatar
Car: 89 GTA, 89 Z-28, 96 Firebird
Engine: 5.0 TPI, 5.0 TBI, 3.8L
Transmission: stock 700-r4
Axle/Gears: stock
Re: Fuel Gauge
It is called a "fuel tank sending unit" and you probably will have to order it from a special place. Depending on your application, you might have to dig deep into your wallet. I know that for a 1996 firebird, the sending unit costs around $600. I would drop the tank and check power, and if something stupid might be wrong. Good Luck.
Old Jul 1, 2008 | 06:16 PM
Engine: 5.7 350 TPI
Re: Fuel Gauge
Yeah I just looked into it and its just shy of 200$ for my car. My only worry is that that may not be it though thats what I was told it is. I dont have the means to lower the tank and check it out myself. So Im kinda stuck here. I dont wanna buy that part and have that not be the problem.
Old Jul 1, 2008 | 09:11 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Fuel Gauge
You should try shorting the sender wire to ground. If the gauge and wiring is good, it should go to E. The other thing to try is grounding the tank and see if the gauge starts working.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
justin57
Aug 20, 2015 07:05 PM
Jk_Under
Aug 17, 2015 03:08 PM
R3500
Aug 17, 2015 12:16 PM
