surge problem @ 5500rpms
Old Jul 9, 2008 | 07:41 PM
Average Joe's Avatar
I recenlty started to notice my car has a really bad surge when I rev the car beyond 5500rpms while in park. I normaly don't make a habbit of reving my car in park, but I have had a backfire issue. I can run up to a 100 shot with no problem. If I run the 150 shot, my car backfires once I hit 5000+ rpms. The car never has had any issues till recenlty with no new items put on the car & or no new issues..............till now!
Replaced cap, rotor, plugs, module.
Old Jul 12, 2008 | 06:06 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Re: surge problem @ 5500rpms
"If I run the 150 shot, my car backfires once I hit 5000+ rpms."
Nos is an oxygenator, you need a bunch more fuel to run a 150 shot.
Save your money up for a new motor. You are running the motor lean, it will literally melt the pistons.
Old Jul 12, 2008 | 07:37 PM
No, I think it's rich. I'm getting popping out the exhaust, no detonation. If I were getting detonation, then, yes, I would suspect its running lean. My plugs are rich. I see raw fuel out the exhaust when I have the backfire..or I should say afterfire. Timing is @ 6 advanced, plugs @ .35.
Old Jul 13, 2008 | 08:43 AM
Well, my car has a surge and backfire with out using the n2o. I get a surge @ 5500rpms and occasional backfire?
What would cause a miss @ high rpms and a backfire?
Old Jul 14, 2008 | 01:57 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Ignition breakup or valves floating.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
