DIY TPI AFPR (adjustable fuel pressure regulator)
Old Jul 24, 2008 | 03:12 PM
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I am modifying a stock TPI fuel pressure regulator (FPR) to make it adjustable. I would like to change the spring so that it is softer. Anyone know of a good source for similar sized springs? The goal is to use the stock TPI FPR and make it be a rising rate AFPR for boost. That is, instead of the stock 1:1 rising rate I would like to intall weaker spring and make it around 4:1 (4 PSI of fuel for 1 PSI of boost).
Years ago there was a webpage that showed a DIY TPI fuel pressure reg. mod.
Old May 13, 2009 | 04:14 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: DIY TPI AFPR (adjustable fuel pressure regulator)
i dont understand what your asking. to make it adjustable you dont need a smaller spring, if you drill and tap a hole in the top of th housing and put a small washer above the spring inside the housing the farther you screw in(compressing the spring) the higher the psi you will get. im not 100% on which way you screw it in but ive heard of peole putting pennys above their springs for a higher psi.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
