Carb to TPI Convertion Wont Stay Running in Run Position
Old Jul 25, 2008 | 07:25 PM
ar1424's Avatar
I've converted my 1975 Chevy Truck to TPI from 1991 Firebird 5.7 GTA. I've modified the donor's wiring harness without emission stuff. I order new EPROM without VATS and emission stuff. When on "Run" position I can hear the fuel pump run then stopped (maybe pressure buildup then stop) when I start the truck the truck starts, as soon I let the key go to "Run" position engine dies.
I've used the truck existing coil positive wire (hot while start and run). Ran the ECM and fuel injector wire with 10A fuse on the fuse block terminal hot while Start and Run position. Please help I'm sure I got everything connected or the truck wouldn't start at all.
Old Jul 25, 2008 | 07:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Carb to TPI Convertion Wont Stay Running in Run Position
How are you powering the fuel pump?
Old Jul 25, 2008 | 08:02 PM
ar1424's Avatar
from the ECM with relay...I kept the existing fuel pump relay and wiring. I ran gray wire from GE13 pin of the 7730 ECM to the fuel pump "+" terminal.
Old Jul 25, 2008 | 08:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Is the pump still running when you stop cranking?
Old Jul 25, 2008 | 08:16 PM
ar1424's Avatar
yes still running I believe...when the engine stop I can hear the fuel pump running...by the way I'm using inline fuel pump from Walbro.
Azrael91966669
25
Jun 20, 2017 04:04 AM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 17, 2015 02:00 PM
