injector constant and closed loop - how far off can it be?
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
How far off can the injector constant be, yet still be in closed loop?
I've been trying to nail down my injector constant, like forever, and I just can't get closed loop for more than a few seconds - no O2 swinging. Tried Bosch O2, AC heated O2, now Innovate WB O2 (simulated NB). Also tried flow matched LS1 and new Accel 21lb injectors.
I tested the O2 signal on the ECU harness and the ECU board and WB says 14-15:1.
I'm not sure where to go from here. Any suggestions?
Anyone know of a good TPI tuning place in SE PA?
Car: check
Engine: check
Transmission: check
Re: injector constant and closed loop - how far off can it be?
Up until the last sentence your post was OK on diy_prom, moving to TPI board.
{Not a referral service.}
RBob.
Car: 89 GTA
Transmission: 7004R
Maybe I should have asked, "just how adaptable is an O2 sensor- just to get to closed loop?"
The reason I ask is that the engine temperature is good, and my AFR is close and I figure the only think left is to narrow down the inj const., or something is malfunctioning.
I figured I need to get it closer but I am at the point where I am changing from 22.00 to 22.2 and being just rich and just lean.
Car: 89 GTA
Transmission: 7004R
FYI: It's been a while but I finally got it -
I cut the tan wire and attached it to the body and instantly saw the O2 swinging - thanks for the help
