O2 confusion - 0v is lean, 1v rich?
Old Apr 25, 2008 | 08:51 AM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
Been trying to figure out why my 89GTA won't go in closed loop. O2 in datalog is at 444, no xcounts, open loop.
Hooked a good meter (digital fluke) up to the O2 at idle (with O2 connected to computer), engine hot. Reads under .1 and I thought that means lean so I'd richen it as a test by spraying starter fluid into the intake.
When I removed the filter housing and the O2 volts jumped to .7! (it's repeatable) Wouldn't letting more air in make it leaner? Does .7 indicate a lean condition - or is my sending reversed readings?
I am running ls1 injectors, vortec heads, scoggin-dickey intake, Edelbrock headers, new heated AC O2 (setup bought from tpi_parts), running ARAP PROM
thanks for any insights!
Old Oct 9, 2008 | 08:55 AM
Car: 89 GTA
Transmission: 7004R
Re: O2 confusion - 0v is lean, 1v rich?
FYI: It's been a while but I finally got it -
I cut the tan wire and attached it to the body and instantly saw the O2 swinging - thanks for the help
Cg-OneSic89
Oct 21, 2009 01:45 PM
rhuarc31
Sep 15, 2007 06:54 AM
IonNight
Jun 5, 2005 09:52 PM
RICHRAD
Carburetors
Sep 13, 2003 05:42 PM
Homer
Carburetors
Sep 11, 2002 02:22 PM
