what goes on the TPI intake?
Old Aug 1, 2008 | 07:26 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
as some might know im converting to TPI, i got the whole engine but all it has for the intake is the snorkel. is there a MAF sensor that goes inbetween? the guy said something about an an flow meter? which is basically the same thing. any links to a picture or an actual picture to show me what im looking at? i need to get one before i drop it in, or at least by the time im ready to fire her up. thanks TPI guys!
Old Aug 1, 2008 | 07:34 PM
F-Body Demon's Avatar
Re: what goes on the TPI intake?
It depends on what year the computer your going to use came from. 85-89 use a MAF sensor, but 90-92 use speed density which doesnt need anything.
Old Aug 2, 2008 | 12:33 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
hmm well i believe its from an 89. im looking on TPIparts.net and im seeing them go for, well a rebuilt MAF sensor is 220 but a MAF sensor KIT is also 220 but i dont know what the differ is. this sucks though cuz i gotta fork out hundreds more now for this swap to be effective.
Old Aug 2, 2008 | 12:46 AM
Thats true I guess. BUT! You will be running a much more forgiving system. Me if I mod my speed density I have to go in and tell the computer what happened for it to be effective, you do not. If I put on a H/C/I setup, sure I will gain power...but not as much as you would with the identical setup. Not until I tuned it at least then it would be about the same, or within 5-10hp.
Old Aug 2, 2008 | 02:45 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
so your saying i can buy a Mass Air Flow sensor, bolt it in, and just go? i just want all stock right now nothing outrageous. and your saying im lucky i dont have a speed density thing?
ive replaced a MAF sensor before its just bolt and plug in. so im guessin on what you told me, thats all i gotta do and not have to tune anything?
thanks again
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
masonta
Aug 31, 2015 10:14 PM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
