Car has no power and is slow
Old Jul 29, 2008 | 05:08 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I posted in the general engine section also, but I figured I should now post it here since it is a TPI engine. The car has a lot less power than it should and I cant figure out what is causing it not to have the power it should. It is a 305 TPI, and has a Comp Cams computer controlled cam in it (260/260 duration .444.444 lift 112LSA). When I start the car up when it is cold, it will stall unless I give it gas. Once it gets warm though it will stay runnning. I have looked and I dont see any vacuum leaks anywhere at all. The throttle response isnt very good on it at times. What should I start looking into?
Old Jul 30, 2008 | 06:39 PM
F-Body Demon's Avatar
Re: Car has no power and is slow
Throttle Possition Sensor sounds like the place where I would start. Sounds to me like your computor isnt giving your engine the fuel or timing it wants.
Old Jul 30, 2008 | 07:06 PM
ParkerTPIz's Avatar
uuuh either the TPS or the CTS (coolant temp) is out.
if neither of those fixes the problem, maybe u have to advance the timing to coincide with the cam.
Old Jul 31, 2008 | 08:16 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
How can I tell if it is the CTS that is bad?
Old Jul 31, 2008 | 10:41 AM
ParkerTPIz's Avatar
u can test the ecm and check for codes.
take it to autozone. they do a free diagnostics test.
or if u want, just replace it, its only 15 bucks, i think. then if u have the same problem, u know it wasnt that.
Old Aug 1, 2008 | 06:24 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I swapped the TPS for another one that I had laying around, and no change. I advanced the timing more also and no change. Do you think that the problem could be the cam that I put in it, being that it might be a little to big?
Old Aug 1, 2008 | 07:45 AM
ParkerTPIz's Avatar
i dont think so......but maybe
try the CTS. if that doesnt fix it, then u may have cam issues.
Old Aug 2, 2008 | 06:56 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Im going to try re-adjusting the valves again today, this time trying it with the engine running.
Old Aug 2, 2008 | 11:16 AM
ParkerTPIz's Avatar
dude, seriously.. it sounds like the CTS. ive had it happen to 3 of my vehichles. try that first.
Old Aug 2, 2008 | 12:36 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Ok, ill try the CTS today also. One thing that I found today that seems like a huge problem is that I was thinking that not all the injectors might be firing, so while the car was running I pulled the injector clips off the injector to see what kind of difference it would make, and after pulling one by one on the passenger side, the engine would idle down, but after pulling them on the driver side, it didnt make any difference at all. So im guessing that maybe my injectors are screwed up on the driver side?
Azrael91966669
25
Jun 20, 2017 04:04 AM
Brcharrelson
Aug 26, 2015 07:47 PM
novaderrik
Aug 10, 2015 12:44 PM
86Base
Aug 8, 2015 01:34 PM
