I dont want to pay $100 to have the chip burned just to delete the cold start ( I aready have the fan switch turning on at 176) and I cant really afford to buy my own burning stuff right now. What would happen if I deleted it without taking out of the chip?
It'll just take longer to start when, as it says "it's cold." more so now that you've modified it to take longer to warm up. The cold start is activated on every start, but shouldn't be noticeably longer after on/off cycles once it's at operating temp.
You didn't reprogram the chip, but you did change the T-stat to match?
I bought it with a 160 thermostat from stant, I installed the hypertech fan switch and everything is working fine interms of the tstat opening well before the fans kick in. She doent get driven in the winter time.
Quote:
My cousin and I both simply disconnected the 9th injector since our cars are non-winter. Never had any problems. I don't think you'd have a problem deleting it without burning a new chip.Originally Posted by wanab03ss
I dont want to pay $100 to have the chip burned just to delete the cold start ( I aready have the fan switch turning on at 176) and I cant really afford to buy my own burning stuff right now. What would happen if I deleted it without taking out of the chip? yeah!!!!!!! thats what I wanted to hear.
The opposite is true too, I run a prominator and switch between ARAP and 32 and 32B chips without touching the cold start. The prominator has room for 8 different 16K bins. Right now I am data logging ABTD (32B) and ARAP (6E) in a stock 87 vette. The ARAP does not drown in fuel from two sources. I am not sure why but I could see no difference in the data logs or notice any cold (open loop), starting or driving, differences or issues.
WDYTATA?
WDYTATA?
Quote:
WDYTATA?
I dont understand much of anything you said. Cold start what, 87 vette who ? Originally Posted by pandin
The opposite is true too, I run a prominator and switch between ARAP and 32 and 32B chips without touching the cold start. The prominator has room for 8 different 16K bins. Right now I am data logging ABTD (32B) and ARAP (6E) in a stock 87 vette. The ARAP does not drown in fuel from two sources. I am not sure why but I could see no difference in the data logs or notice any cold (open loop), starting or driving, differences or issues. WDYTATA?
..... some day Ill start burning chips and then we can have a nice talk..lol. thanksSenior Member
Only problem I had in my 86 when I deleted the CSI was at start-up.Needed to put some pressure on the gas pedal to get and keep it running.Once warmed up would idle and run perfectly.
Quote:
My cousin's been unhooked for about 6 years, and mine for a year, and neither of us has ever had a problem. The only time I could see that happening is if you try starting it when it's very cold out. We don't; and the OP said his car is stored winters also - shouldn't be a problem.Originally Posted by IROCZ4BD3
Only problem I had in my 86 when I deleted the CSI was at start-up.Needed to put some pressure on the gas pedal to get and keep it running.Once warmed up would idle and run perfectly. Senior Member
The cold start (the ninth injector), (does the same function as a "choke" on a carburetor), was dropped in 1989 on the TPI Cars (Camaro, Trans Am and Corvette). The "additional fuel" was provided by a software change that used the other eight injectors.Originally Posted by wanab03ss
..... some day Ill start burning chips and then we can have a nice talk..lol. thanks WDYTATA "What do you think about those apples".
HTH "Hope this helps"
I think he was referring to all of the PROM lingo you threw at him, when he simply wanted to know if it would work or not. Just seemed like you went too in depth. Correct me if I'm wrong.Originally Posted by pandin
The cold start (the ninth injector), (does the same function as a "choke" on a carburetor), was dropped in 1989 on the TPI Cars (Camaro, Trans Am and Corvette). The "additional fuel" was provided by a software change that used the other eight injectors.WDYTATA "What do you think about those apples".
Kevin91Z
close
- Join DateJul 1999
- LocationOrange, SoCal
- iTrader Positive Feedback100
- iTrader Feedback Score(1)
- Car1990 Pontiac Trans Am
- Engine355 TPI siamesed runners
- TransmissionTremec T56
- Axle/Gears12-Bolt 3.73
- Liked:26 Times in 22 Posts
The cold start injector only works when the temp is less than 40 degrees F, and it only sprays fuel for a second or two, then it shuts off. You can safely disconnect it if you live in a warmer climate, but it doesnt hurt to leave it.
