Mystery starting problem
Old Aug 3, 2008 | 11:52 AM
Daniel Golden's Avatar
Help, I need help with my 89 Iroc Conv. The problem is: My car stopped running about a year ago. It turns over fine but won't start. I changed the Fuel filter, then fuel pump, completly dissassemble then re-assembled the fuel rail, and removed the pressure regulator. it looked ok, no tear in it. I tested the injector circuit and fuses are good, power is getting to injectors one the fused side. It will start if I spray starter fluid in it but only for a moment. I also swaped the computer, and coil. It is getting sprak but not fuel. Idid a pressure es and it was also fine, just below 40 psi.
Oh, and there are no ALDL codes displayed, code 12 returned on diagnostic check.
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
