Removing Plenum and Runners
Old Aug 8, 2008 | 08:42 PM
TurbomanKnight's Avatar
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
My car has a bad head gasket.. So today I started unplugging harnesses and vacuum lines. Took the plenum out and thats where the trouble started.
I stripped the head of one of the Torx bolts on the runner. It's the one on the right side of the car closest to the front of the engine.
I tried using a vice grip to get it off but it isnt working out. Anyone have any ideas?
Old Aug 8, 2008 | 09:09 PM
norcalace's Avatar
Re: Removing Plenum and Runners
You might try an allen in a 3/8 drive socket. Try tapping it into the torx bolt.
Also you might try tapping on the bolt head with a brass drift to help break the set of the bolt. Blaster penetrant might help too.
Old Aug 8, 2008 | 09:35 PM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
http://www.sears.com/shc/s/p_10153_1...=Taps+%26+Dies
Old Aug 8, 2008 | 11:08 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
screw extractor, u can find it at any hardware store, you could try your luck with a thin metal file or maybe a dremel if u have it to make it a flat head shape and then try to twist it out
Old Aug 9, 2008 | 04:54 PM
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Thanks for the suggestion guys, got it out with a chisel and a hammer.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
