need switched power source
Old Aug 10, 2008 | 01:44 PM
the blur's Avatar
I need a switched power source from under the hood. I don't really want to hack up the factory wiring harnesses, as the car is a show car.
where should I look ? any relays that are simple to get to ? and not hack up too badly???
It's a 1989 TPI motor.
Old Aug 10, 2008 | 01:57 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: need switched power source
why not run the wiring to the fuse block inside under the dash? i have mine all run in there and it should have empty spots in it that a spade connector will push right into for a switched power source. just make it looks clean under the hood with wire loom.
BRoss99
Aug 10, 2025 05:08 PM
89GTAOz
May 16, 2020 09:31 AM
gta90
Sep 15, 2015 04:00 PM
soarestransam
Sep 1, 2015 04:00 PM
ZsTransAm
Aug 11, 2015 07:30 PM
