water pump?
Old Aug 11, 2008 | 05:28 PM
armygreen87's Avatar
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Transmission: 4-speed automatic
Axle/Gears: 2.77
water pump?
ok, I have an adjustable fuel regulator, but the darn auto store gave me a compression tester instead of a fuel pressure tester. so until i can go get the correct part, i gotta assume my fuel pressure is the reason im still overheating. is it possible though, that my water pump is no good? what are the signs of a bad water pump?
Old Aug 11, 2008 | 07:53 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: water pump?
It's unlikely that your FP is causing the overheating. A bad water pump is one that's leaking. If it's not leaking, it's likely fine. Is you fan(s) coming on? Have you tried changing the thermostat?
Old Aug 11, 2008 | 08:20 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Re: water pump?
could be the fan...just replaced one of the fan motors, the one on the drivers side, is that one the main fan or just the heater/AC fan? prolly should replace the other motor too... just replaced the thermostat today and thats why i was puzzled.
Old Aug 11, 2008 | 08:54 PM
jv9999's Avatar
Engine: 5.7L/350
Re: water pump?
One fan is turned on by the ECM at around 220F. The second one is turned on by a switch in the passenger side head (or by a switch in the A/C compressor). It should come on around 235F. If you're overheating and both fans are not running, that's likely your problem.
Old Aug 12, 2008 | 09:30 AM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Re: water pump?
havent looked at them while it was overheating...i'll give it a try. but then again, the way my car used to be, it never even got up to 220 unless i idled for a long time. It never got that high while i was driving it (so it wouldn't need the fan), but now it is. so something else may be wrong.
Old Aug 12, 2008 | 09:37 AM
jv9999's Avatar
Engine: 5.7L/350
Re: water pump?
Does the radiator get as hot as the engine? If not, it might be a bad thermostat.
Old Aug 12, 2008 | 06:35 PM
Car: 1989 IROC-Z28
Engine: 5.7 TPI
Axle/Gears: 2.77
Re: water pump?
replaced the thermostat yesterday before i took it for a drive though
evilstuie
Jan 9, 2020 08:29 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
RyanJB
Sep 2, 2015 01:27 PM
Dialed_In
Aug 20, 2015 01:45 PM
