Carb to TPI swap does inline pump need regulating?
Old Aug 21, 2008 | 09:57 PM
tonythetoad's Avatar
Car: 91 convertible, 89 TTA, 03 GT2
Engine: 5.0 TBI, 3.8 Turbo, 3.6 Twin Turbo
Transmission: 700r4, 2004r, 6 Speed
Axle/Gears: 2.73, 3.27
Hey everyone, i am in the process of converting from carbed to TPI im fine with all the wiring i had a donor car. I have the intank pump and tank setup but it gave me probs in the old car. What im wondering is, if i put an inline pump in (which i really want to do!) Taking the tank out of the donor car after it was flipped on its side and i had zip cut 90% of things in the way it was still a you know what... to remove. Do i have to put a fuel pressure regulator? the tpi setup already has one doesn't it? Is all i need to do is just put on an inline pump? My setup is just a 305 TPI with a mild cam nothing else. Thanks for the help.
Tony
Old Aug 22, 2008 | 01:56 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Carb to TPI swap does inline pump need regulating?
I'm not familiar with using an external fuel pump, but yes there is a fuel pressure regulator on the TPI fuel rails. Its the round black piece.
Old Aug 22, 2008 | 09:15 AM
So i just want to make sure that i can just bolt on an msd inline pump and that all. Do i need to get the same psi as the stock pump? or will the stock regulator deal with everything to match up an aftermarket inline with the stock intank.
Thanks for your help,
Tony
Old Aug 26, 2008 | 11:19 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
adjustable fuel preasure regulator
theshackle
Mar 5, 2017 06:37 PM
NBrehm
Aug 25, 2015 11:49 PM
beachrodder
Aug 25, 2015 08:05 AM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
