305 TPI help please
Old Aug 22, 2008 | 11:47 PM
lezanic83's Avatar
305 TPI help please
For all the TPI brains out there. My car feels like it hits a brick wall sometimes starting as low as 3000 rpm. it does it every time you get the rpm's up. hot or cold. i can run it the hour drive to work and it does it when i pull into the parking lot at work. the list of parts i have put in are:
Fuel filter
Spark plugs and wires
rotor
Dist cap
pick up coils
asm module lx315t
Also i did have the fuel pump checked and it was putting out normal pressure(not sure what it was at this time)
This car is bone stock and to give as much info as i can think of it had been parked for 4 years before i purchased it about a month ago
Any help would be great im dumbfounded and my total lack of knowledge on TPI systems is not helping.
Old Aug 23, 2008 | 02:44 AM
cronsformula350's Avatar
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
Re: 305 TPI help please
Sounds like it can be a bad ignition module, because as they start to fail, when they get hot, they make the ignition not work as well as its supposed to, so it runs crappy. Also check your CTS, EGR, and all of your sensors. I'm almost done with school for becoming an automotive technician, so you can check those things.
Old Aug 23, 2008 | 10:09 AM
lezanic83's Avatar
i will have to check those. also if it helps the computer is not throwing any codes
Old Aug 26, 2008 | 11:13 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
helms manual
Old Aug 26, 2008 | 11:20 PM
lezanic83's Avatar
i will have to get one thanks for the info.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
