TPI Codes And Problems
Old Aug 23, 2008 | 02:58 AM
extrat162's Avatar
Car: 1989 IROC-Z
Transmission: 5 Speed
89 IROC-Z with 305 TPI. Codes that I got tonight were: 14, 22, and 44. The two that I'm mainly concerned about are 14 and 22. I replaced the Temperature Sensor (code 14) and it still throws the code so I'm not sure where to check to rid myself of that problem.... any ideas. The other (code 22) for the Throttle Position Sensor is a problem. How do I check to see if the TPS is good or bad and if its bad can I fix it or do I need to buy a new one. Any ideas??
Old Aug 25, 2008 | 01:29 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: TPI Codes And Problems
If the TPS is bad, get a new one and calibrate it according to this article:
https://www.thirdgen.org/tpimod2
Old Aug 26, 2008 | 11:08 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
if you want to keep the car buy the helms manual
Old Aug 26, 2008 | 11:28 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Checking the TPS is easy. You have to have a good voltmeter. The side of the TPS should say A, B, C for the three wire attachments. I think that you should be checking the voltage across A and C. Turn the key to the ON position, do not start the engine. The idle voltage should be 0.54 +- 0.08 or close to that. Then, by hand, slowly opening the throootle blades to WOT. The TPS voltage should slowly climb higher in unison (sp?) with the throotle being opened, and stop somewhere above 4.0V... Check out the Technical Articles on this matter on the home page here.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
gta90
Sep 15, 2015 04:00 PM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
