bolt sizes for runners to plenum, and fuel rail to manifold
Old Aug 25, 2008 | 04:19 PM
torqueaddict's Avatar
Car: 89 GTA
Engine: 5.7 ZZ4 Vortec TPI
Transmission: 7004R
It looks like there are 4 bolt sizes for the rail to manifold and runners to plenum and I want to make sure I'm getting it right.
I know the longest ones (4?) go in the center lower runners to manifold, and after that, I'm not 100% sure.
Are the fuel rails the same size as any of the runner bolts?
thanks!
Old Aug 25, 2008 | 06:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: bolt sizes for runners to plenum, and fuel rail to manifold
on my setup, the fuel rails are 10mm sockets.
The runners are all torx.
Longest go to the lower middle of the runners (qty 4)
next shorter go to the sides of the runners to base (qty 4)
next shorter go from the inside to out on the back side of the runners. One is left rear back by the dizzy, the other is pass side up front basically under the TB (qty2)
shortest are 4 runners to base, then 8 runners to upper (qty 12)
http://tpiparts.net/inc/sdetail/559
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Andrew6.688
Dec 13, 2015 10:59 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
knight72
Aug 10, 2015 09:32 PM
92projectcamaro
Aug 6, 2015 01:20 PM
