iTs smog time in Cali!
Old Aug 31, 2008 | 12:06 AM
Chillenaj's Avatar
Car: 1991 Camaro convertable
Engine: 305 T.P.I.
Transmission: 700 r4
Axle/Gears: stoCk
Hey all Adam here just got my smog noties today, and wondering what are some things i need to look over on my Camaro(91 305 tpi) had a tun up about feb and everthing seem ok ,, but these days ive got a little peoblem at start up,, first it pick its days when it wants to start right up, i think i have a choke problem, ok, ill start it and will not idle at all with out me feathering the gaS, other times it starts right up, (hot or cold) dont matter. as well as some times it stays on way too long after start up. I replaced my IAC valve, but still i was told that it could be just some build up around the valve hole...
and whats the best way to test my Catalitc converter?
Old Aug 31, 2008 | 02:49 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: iTs smog time in Cali!
When you replaced the IAC valve, did you clean out the throttle body with carb cleaner spray? It's amazing how much black gunk comes out of a seemingly clean throttle body.
I don't know of any way to test a catalytic converter without actually doing an emissions test.
I'd say get a new PCV valve. They're cheap. Make sure the valve on the passenger side valve cover is closed. I've found mine popped open twice in the past. (It's hidden beneath the AIR tube). Go for a nice long highway cruise to "burn the gunk" out of it as Bill Cosby used to say.
A new AC Delco oxygen sensor helps with emissions. Other than the general tune up you did, you should be fine.
onefreakz
May 14, 2018 12:15 PM
italiano67
Dec 11, 2016 09:21 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
camaro_rs350
Northern California
Aug 18, 2015 12:38 AM
mustangman65_79
Aug 7, 2015 09:55 PM
