Few easy questions for tpi 350
Old Aug 30, 2008 | 04:07 PM
91firebird350's Avatar
Car: 91 Firebird Formula 350
Engine: TPI 350
Axle/Gears: 3:23
Hey i have a question about my motor that i couldnt find answers to doing a search.
I want to get an throttlebody air foil and i have seen some that come with a gasket for under the tuneport plate. does this need to be replaced or do most come with them.?
I want to add an air intake onto my car, simular to the ones offered on ebay. will that help make my exhaust lounder. I have the 3inch Flowmaster setup with the 80 series muffler.
I see alot that the L98 is compaired to the LT1 motor. are these the same/simular.?
Last of all, what cars came with the digital gauge setup.
thanks
PS can someone please expalin where the term Snake Oil came from or is about.
Old Aug 30, 2008 | 04:26 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
Re: Few easy questions for tpi 350
thanks
I don't believe you have to change the t/b gasket,an airfoil and CAI is a good upgrade but I don't believe it will make your exh. louder(im assuming thats what u meant by lounder?)
lt1's are quite a bit diff. than l98's
and on digital gauges,some of the 87-88 gtas/tas had them and some mid 80's berlinettas also not 100 percent sure on years&numbers
Old Aug 30, 2008 | 05:57 PM
pandin's Avatar
Car: 86 vette
Engine: 383
Axle/Gears: 3.07
Snake oil is from the pre FDA drug days when anybody could sell anything as a medicine. It is a slang term for "all hype and no value".
Think about a "Hawker" standing on a street corner telling you how great something is and it turns out to be just sugar water, for $10 to $100 a bottle (the $100 stuff is better because it cost more ).
PT Barnum said " There is a sucker born every minute."
Old Aug 31, 2008 | 07:01 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Some airfoils require that the IAC plate be removed in order to install the airfoil. That's what the gasket is for.
Also, my 88 TA has the digital dash.
Old Aug 31, 2008 | 08:11 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
both the lt1 and l98 are fuel injected, 5.7lt, V8s, but that is just about as simmilar as they get. the l98 was rated at 240hp/ 340lb/ft torque. the lt1 305 hp/ 325lb/ft torque.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
st.evel07
Aug 13, 2015 06:15 PM
gta power
Aug 13, 2015 06:15 AM
Sanjay
Aug 12, 2015 03:41 PM
