305 trans am tps
Old Aug 25, 2008 | 09:38 PM
jimc1987's Avatar
Car: 1987 pontiac trans am
Transmission: 700 R 4
305 trans am tps
I had changed the tps in my car and it idled and ran fine for about a day then the next day i went out to start it and it did the same thing it did before it just would not idle i am pretty sure its the tps but what could be shorting it out since it is a new one any help would be good the car is a 1987 trans am with a 305 tpi
Old Aug 26, 2008 | 08:27 AM
jimc1987's Avatar
Re: 305 trans am tps
anyone got any ideas
Old Aug 26, 2008 | 01:11 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
computer.
Old Aug 26, 2008 | 11:02 PM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
what did you set it to
.54
Old Aug 27, 2008 | 11:43 PM
dwillis's Avatar
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
sure its not the iac?
Old Aug 31, 2008 | 01:17 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
The TPS has to be set at the correct voltage of .54 or very close for it to work properly.
Old Aug 31, 2008 | 08:39 AM
jimc1987's Avatar
Thank you all for your guys help i havent had much time to look cause im getting married on the 6th but i will check everything you guys suggested ill make sure i double check the voltage too im not sure when i can do this but i will keep you guys posted
jklein337
Sep 19, 2018 06:23 PM
Sanjay
Aug 12, 2015 03:41 PM
3rdgenparts
Aug 6, 2015 09:03 AM
Leggman1
Aug 6, 2015 04:15 AM
