How would this motor setup turn out?
Old Aug 31, 2008 | 08:25 PM
danielmonster's Avatar
Car: 1985 IROC
Engine: lb9
Transmission: 700R4 B&M shiftkit
Axle/Gears: 3.42s
What I have planned as of now:
rebuilt 1998 vortec 350 4 bolt main
modified '062 casting vortec heads, 918 beehive springs
1.52 pro magnum full roller rockers
comp cams cc306 (230/244, .510/.540, 112LSA)
vortec stealth ram with afpr
high volume fuel pump
ford racing 24#/hr injectors (will these be enough for 6500rpm?)
long tubes into 3" Y
granatelli maf
tuned
Someone please give me some input on this combination. Just from curiosity, I entered the above into engine simulator 2000 and it showed 439fwhp @65000 rpm, but these numbers sound a bit tall. I would be content with 400 fwhp. What do you guys think?
Old Aug 31, 2008 | 09:24 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: How would this motor setup turn out?
I'd say over 400fwhp. It's pretty easy to do that with a small block. I had mine making 405rwhp n/a with a 246/254 .558/.558 cam before the blower/compression drop. I wouldn't put 450rwhp out of the question with my new cam 264/271 .626/.626 if it had 10.5:1 compression or more.
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
TheExaminer
Aug 19, 2015 10:07 PM
Street Lethal
Aug 13, 2015 08:28 PM
