1989 TPI dies when you stab and release the throttle under load
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Ok, car idles well, revs up fine, roasts the tires at will when you floor it, but its started to have this strange issue. Under load, and much more noticable in reverse than forward, if you stab into the throttle VERY abruptly and release, car responds, then dies. I just set the timing (thanks for the help guys), but I have not set the idle. TPS is set correctly (0.54V). Brand new plugs, wires, ignition module, cap, rotor. MAS is not new, TB is from the wreckers. Any ideas????
Car: 1988 trans am GTA
Engine: 350 V8 tpi roller motor
Transmission: 700-R4
Axle/Gears: 3.73 b/w posi will change out soon
Re: 1989 TPI dies when you stab and release the throttle under load
clean out the IAC that controls idle and controls rpm under 1500
Car: 1987 Iroc-Z
Engine: 5.7L SB
Transmission: TKO 500
Axle/Gears: 10 bolt 373's and a Detroit Locker
That sounds very similar to what i had a few months ago and i changed the mas with a buddy of mine who has an 87 bird and it was fine so i just had to change the mass and it was fine but you definitely have an Air fuel ratio issue imo with out looking at it... Any check engine lights?
Car: 1989 IROC-Z
Transmission: Th700R4
I had the same issues long time ago, Turned out to be 2 bad injector.
So Check your injectors. Also, check your fuelpressure.
If your injectors are bad, Then I recommend Bosch III from FIC.
Jon sells 8 Bosch III for 169,95 with 3 years warranty.
They are flowmatched and they have a great spray pattern. I use them myself and I never had better injectors and smoother idle and throttleresponse.. So I really recommend Jon at FIC
Engine: L98, LG4
Ok, thanks for all the help. Changed out the TB for a cleaner one, cleaned the IAC and the TB, reset the TPS and the idle screw. Works much better, still a stumble as you accelerate from a dead stop. I'll see what I can do about getting the fuel pressure checked and I'll switch to another MAS and see what happens. Thanks!
theshackle
Sep 17, 2020 08:26 AM
Sanjay
Aug 12, 2015 03:41 PM
