305 TPI Injectors Question
Old Sep 11, 2008 | 10:45 PM
amichals's Avatar
I looked all around the website and I cant find any help so I need to know if i have an 89 305TBI set up camaro with the wiring harness still in it. What all do I have to modify to get the 305 TPI engine to plug up correctly with all the wires. I have a complete 305 TPI engine with everything on it and all the injectors wires still on it just cut. Since the TBI only has 2 injectors how do I go from that 2 to the 8 injectors needed for the LB9. I also have the ECM and fuel pump for the Tpi so is that all I need to worry about is going from 2 injectors to 8? Thanks for the help.
Old Sep 12, 2008 | 08:00 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: 305 TPI Injectors Question
As far as I know, you will need to get a TPI wiring harness with a computer & chip from a 305 TPI car. I'm not aware that you can modify a TBI harness to make it work with TPI.
Old Dec 16, 2008 | 01:42 AM
1986Z28OWNER's Avatar
Car: 1979 Malibu
Engine: Blown LSx
Transmission: T56 Magnum
Axle/Gears: 9"/wavetrac/35's/3.70
A TBI harness can be modified to work with a SD TPI setup. it involves cutting and splicing in more injector connectors, lengthening connections for TPS and IAC, and repinning the ECM plugs, mroe work than its worth, just track down a true SD harness.
Brcharrelson
Aug 26, 2015 07:47 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
