What's a good intake paint?
Old Sep 16, 2008 | 06:43 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
I'm looking to paint my plenum, runners, and base when I buy the edelbrok high flow.
What is a GOOD paint to use that will stand up to the environment and temps of an engine?
I'm looking to do a base coat of gloss black and red highlights and then top it off when a nice shiny clear.
I don't have any fancy equipment or a place to do it so although I knowit isnt the best route to take, are there any recommended rattle can products out there?
Old Sep 17, 2008 | 01:29 AM
Car: 1985 Z28
Re: What's a good intake paint?
Just wondering if this:
http://performanceparts.com/part.php?partID=5921
And It's recommended clearcoat would be a good choice.
Old Sep 17, 2008 | 05:32 AM
paulisgod's Avatar
Car: GM
Engine: v8
Transmission: slushboxes
Paint could be a pain in the butt cause it might chip and peel if not done right. Sorry, can't help you with this subject cause I don't know. What I can tell you is that you could polish your intake parts to a brillant shine and I think that it would look better that way, anyway. Just my opinion, get other opinions, especially Senior Members.
Old Sep 17, 2008 | 07:08 AM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
I just did mine, I took it off and sandblasted it and sealed it with cromapremier sealer and I used napas polyurathane paint to top it off..I could post a pic if u wanted
Old Sep 17, 2008 | 11:19 AM
Car: 1985 Z28
Sure.
Old Sep 17, 2008 | 11:32 AM
NY87Iroc's Avatar
It was sitting for 10 years and someone before me painted the intake black it it was all coming off and looked really bad..I also bought the valve covers on ebay and sandblasted and painted them to...nothing fancy just wanted it to look alittle more factory thats all.
Old Sep 17, 2008 | 12:00 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
I have a TBI intake that I just had powder coated. It looks phenomenal. It is called "mirror finish" with a clear over it. Cost me $65. It was a new Edelbrock TBI #3704. I have seen others paint their TPI/TBI intakes and it's a 50/50 shot whether it will hold or not. My previous manifold was blasted, primed and painted using the best stuff out there and it lasted about 6 months.
The powder coating should last years and cleans up with a rag when you get it dirty.
SOme say that painting/coating an aluminum intake can trap the heat and you can loose a little hp. I have seen no issues.
With my new project I am having almost everything powder coated. Pulleys, brackets, intake, tbi, injector pod, coil bracket, throttle cable bracket, etc. The only reason is due to ease of cleaning and protecting my investment. It was a total of $350 to have it all done.
I also spent about $60 to replace all the nuts, bolts, screws with stainless.
Attached Thumbnails What's a good intake paint?-100_1841r.jpg   What's a good intake paint?-100_1840.jpg
Old Sep 17, 2008 | 12:06 PM
dctrumpet's Avatar
Get a quote on powder coating all of that and any brackets that you have to remove during the process. loss black looks the best on brackets. It would look awesome to have your runners a different color than the rest of your intake. Gloss black and gloss red look awesome. Silver tends to look more "painted" than the rest of the colors for some reason.
Good luck and keep us posted.
Old Sep 17, 2008 | 12:35 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
what about good clear coats? i would love to paint my satin bar aluminum HSR that i have polished slightly on the top rails so it doesnt oxide... but ive heard all the rattle can clears turn it yellow and flake off. i have had experience with VHT brake caliper clear which turned yellow and flaked off. as well as POR15 clear that just flaked off a well. ive heard bad things about engine enamel clear that does the same.. i tried it on my aluninum heads and it does turn it alil yellow tint. so wat are the good clears as well?
Old Sep 17, 2008 | 01:02 PM
dctrumpet's Avatar
To be honest with you I have not seen a clear that works well in the engine compartment other than a clear powder coat. It's unfortunate, but true!
Old Sep 17, 2008 | 03:09 PM
Car: 1985 Z28
What about cleaning up the plenum and runners and runners really good and then hitting it with that high temp gloss black epoxy paint I posted?
Old Sep 17, 2008 | 03:18 PM
dctrumpet's Avatar
Well, the worst case scenario is it will not last. Remember that regular paint still chips and scratches, etc. Not a whole lot of investment in going that route. You can always take it back off if it doesn't work and then have it re-done, but I am one who advocates "save time, save money".
The great thing about powder coating is its durability. IF it scratches you can buff it out and it lasts a long time!
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
ziggy89
Exterior Parts Wanted
Sep 10, 2015 08:44 AM
ElPaleterro85
Aug 13, 2015 03:49 PM
