new to tpi, have a lot of questions, and new project
Old Sep 19, 2008 | 01:28 PM
kylemm1002's Avatar
Just a warning Ive got sum stupid questions so please bare with me...
Ok so I just bought my next project. It is a 85 camaro iroc z28. It is a roller with no motor or trany. The car came orignal 350 tpi and automatic trany.
Im new to tpi and have searched around this site but still have questions.
Can someone post a link of an explaination of how tpi works? like the 9th injector thing?
My plan is to buy a complete tpi 350 and rebuild with high comp pistons and mild cam. I cant afford aftermarket heads so I will be reusing stock heads. And get a automatic trany with prbly 2800-3200 stall converter.
here are some pics:
questions:
what kind of auto tranny came stock in 85 iroc, and does it use a TV cable?
Can I use vortec heads off a truck with the stock intake?
how can I ID a 350 vs 305 when buying a motor?
what is this cable in the pic:::::????
and last any idea what these wires are? the run up to the colum sum where
THANKS FOR THE HELP
This is gona take sum time but I want it running full bore by the summer.
thanks agian
kyle
Old Sep 19, 2008 | 03:29 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: new to tpi, have a lot of questions, and new project
You cannot use vortec heads with the stock intake manifold. You would need to buy a vortec TPI intake manifold from Edelbrock or Scoggin-Dickey.
http://www.sdparts.com/product/SD381...Baseplate.aspx
Old Sep 19, 2008 | 07:24 PM
ironleg's Avatar
Car: 1988 iroc z28
Engine: 357ci
Transmission: 4sp auto
Axle/Gears: stock for now
good looking car did you give much for it?? as far as id you can look at the back driver side of the motor im not sure on older motors but the newer ones will say 5.7 being 350 ci or 5.0 being 305 and trany 700r4 4 speed auto good luck
Old Sep 19, 2008 | 08:12 PM
kylemm1002's Avatar
I traded a 4wheeler for it. and the car will look much better after it gets cowl hood and new paint but first things first....out runing my mustang buddies
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
