TPI Throttle Spring
Old Sep 19, 2008 | 09:30 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
TPI Throttle Spring
Hey guys do the original coil type spring ever go bad or weak? Im asking because someone added a spring and was wondering if the coil spring could be weak. I took off the "added spring" and it felt good and tight anyways. I have a manual so i guess ill drive it and see if i get any throttle return issues.
If worst comes to worst can i put a new spring on??
I did a search and seems like i cant just put a new spring on without taking the TB off and then grinding some spot welds. Can anyone verify this??
LT1Formula
20
Nov 14, 2015 12:02 AM
86White_T/A305
Aug 17, 2015 12:16 AM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
