TPI Temperature?
Old Sep 19, 2008 | 03:18 PM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
TPI Temperature?
Does anyone know what the average surface temperture is for a TPI setup under normal operation?
I got some Epoxy paint rated at 250F to be used on the Plenum and Runners.
Old Sep 20, 2008 | 07:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: TPI Temperature?
Use it. The plenum and runners won't get that hot.
Old Sep 20, 2008 | 10:19 AM
Car: 1985 Z28
What about the intake base?
Old Sep 20, 2008 | 03:51 PM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
The secondary fan will go on around ~238F so it should not be that hot ever, then you got a big problem.. So you can use it.
Hellbillydeluxe
Sep 22, 2015 09:58 PM
LittleFranks
Sep 17, 2015 12:22 PM
g.l.mos
Aug 22, 2015 12:02 AM
Sanjay
Aug 12, 2015 03:41 PM
