Mass air value not changing on autoxray
Old Oct 1, 2008 | 10:30 AM
thekevin's Avatar
Car: 1985 Z28
Axle/Gears: 3.23 open
When i hook up the autoxray it always shows up 32982gr/hr and never changes, that doesnt seem right to me, is my mass air bad.
Old Oct 1, 2008 | 02:25 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Mass air value not changing on autoxray
Sounds like it. It should definitely be changing. That sounds like the max value (ie, an open circuit).
Old Oct 1, 2008 | 03:37 PM
thekevin's Avatar
Car: 1985 Z28
thats kind what i thought, is there any troubleshooting that can be done on it, or just replace it.
Old Oct 1, 2008 | 03:49 PM
jv9999's Avatar
Engine: 5.7L/350
First thing is to clean the connections at both the MAF and the grounds on the back of the passenger side head. I can send you the things to test for later if you have a volt meter.
Old Oct 1, 2008 | 03:59 PM
thekevin's Avatar
Car: 1985 Z28
I will do that tonight, i do have a very nice fluke in fact.
Old Oct 1, 2008 | 05:51 PM
jv9999's Avatar
Engine: 5.7L/350
This might help.
Attached Thumbnails Mass air value not changing on autoxray-maf1.jpg   Mass air value not changing on autoxray-maf2.jpg
Old Oct 2, 2008 | 10:10 AM
thekevin's Avatar
Car: 1985 Z28
i verified i had good ground from the maf plug to the negative terminal on the battery, i also verified i had 12v and 5v on the red and green with the key turned on, does that rule out the relay and lean more toward a bad maf.
Old Oct 2, 2008 | 02:45 PM
jv9999's Avatar
Engine: 5.7L/350
I'd say yea, looks like the MAF. You could monitor the output while it's running (DC, <5V) and see if it changes.
Old Oct 2, 2008 | 04:52 PM
thekevin's Avatar
Car: 1985 Z28
i hooked up my meter to the signal wire and as i blow on the maf the values change, im about to verify the wire back to the ecm is good, if it is then possibly bad ecm?
Old Oct 2, 2008 | 05:21 PM
jv9999's Avatar
Engine: 5.7L/350
Anything is possible, but a bad connection or ground seems more likely. Connect your meter to the ECM end and see if you still see signal.
Old Oct 2, 2008 | 08:10 PM
thekevin's Avatar
Car: 1985 Z28
yes, the values fluxuate with engine rpm, i guess its always possible that my auto xray is just not reading it correctly because when i unhooked the maf while the engine was running and it died shortly after.
Old Oct 2, 2008 | 09:05 PM
jv9999's Avatar
Engine: 5.7L/350
Are you sure it's not set for a newer MAP engine?
Old Oct 3, 2008 | 07:10 AM
thekevin's Avatar
Car: 1985 Z28
its an older xray, i dont have alot of options on it, its set to 85 camaro vin f
Old Oct 3, 2008 | 07:11 AM
george 88gta's Avatar
OK, this is going to sound like a dumb question, but you do know that the scanner has a monitor mode (readings change while engine is running) and then another mode that shows the last reading ( readings are frozen). Check your instructions to make sure you are in the monitor or scan mode. Dont mean to be a smart ***, but I can tell you from personal experience that this is true. Tried to adjust the TPS with the scanner in the wrong mode. Reading never changed.
Also, the car should run with the MAF disconnected, that is a diagnostic technique for determining if you have a basic problem or an electronic one.
Old Oct 3, 2008 | 06:18 PM
thekevin's Avatar
Car: 1985 Z28
what i have found with the scanner is if i am in data mode then hit the scan button it will update with whatever values are given right then, i have been monitoring my temps with it since my temp gauge is also messed up. the car is running really good, it has a slight stumble right off of idle, not as bad after i set the tps to .54 closed.
eightsixseven
Dec 16, 2024 01:50 PM
Keith5
Aug 27, 2015 04:37 PM
chazman
Aug 22, 2015 02:01 PM
Zachattack0925
Aug 12, 2015 09:52 PM
