90 IROC Cyl #2 missing Help....
Old Oct 1, 2008 | 04:17 PM
derekiroc's Avatar
Need some assistance troubleshooting Cyl # 2 missing issue. New spark plugs and wires still has miss problem. Changed fuel pump and this still did not help. Any ideas?
How do I test the injector is ok?
Old Oct 1, 2008 | 09:23 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: 90 IROC Cyl #2 missing Help....
Check the compression on #2 cylinder before doing anything else.
Old Oct 2, 2008 | 06:57 AM
derekiroc's Avatar
Compression around 150. Looks like the injector is not opening, it does not have the tick sound like the others.
Old Oct 2, 2008 | 07:23 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
If the injector checks out OK, remove the valve cover and inspect the valvetrain & rocker studs.
Bill
Old Oct 2, 2008 | 09:32 AM
derekiroc's Avatar
Injector ohms is 16.5 +/-.1 ohm all around. However, if I put screw driver on injector and listen I have several which are very weak sounding compared to others. Not sure what is good since coil resistance seems ok.
Old Oct 2, 2008 | 01:30 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
You could get a noid light to see if that injector is pulsing. My car had two that werent pulsing. Also, is it getting spark to the plug?
Old Oct 2, 2008 | 08:38 PM
derekiroc's Avatar
I checked the pulse voltage at the connector looks ok. Spark is good. I just ordered 8 new injectors, should be here on Friday or Sat. I bought the Bosch 3's which are much better than stock.
Old Oct 3, 2008 | 12:59 PM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
id also bet on a bad injector. Are they the originals? if they are, yes there shot. And even if there ohm'ing ok, they could still be clogged.
Old Oct 4, 2008 | 09:33 PM
derekiroc's Avatar
Replaced all 8 injectors and still have a slight miss and at start it takes till about 3500 to 4000 rpm until it comes alive. Any ideas?
Old Oct 5, 2008 | 01:53 AM
Slow89Iroc-Z's Avatar
Car: 1989 Iroc-Z
Engine: 350ci SBC
Check the valve adjustment on cylinder in question.
Old Oct 5, 2008 | 07:22 AM
derekiroc's Avatar
Still missing, and now the Temp is going to 240 when I run it hard, then back down to 220 and then up again. I guess next is Timing now or distributor. Temp issue, I changed the thermostat which did not help. Can see water flowing in the radiator so water pump seems ok.
What Temp should I run at? and what temp does fans kick on. One fan turns on at 240 and I can not get the other fan to turn on even when AC is on.
IrocBuzz
Camaros Wanted
Nov 20, 2015 11:29 AM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
fasteddi
Sep 2, 2015 10:29 AM
Thornburg
Mid-West Region
Aug 25, 2015 08:20 PM
mustangman65_79
Aug 11, 2015 03:17 PM
