i think my engines flooding out
Old Oct 3, 2008 | 08:07 AM
Jesse's87Z28's Avatar
I had a problem with my fuel pump being plugged in, without the pump plugged in my motor will run a little ruff but runs if i plugg it while the engine is running it dies instantly and no chance of a refire untill i unplugg it then i have to crank and crank finally it fires up. So either the pump is emptying the lines completely or it is filling the cylinders full. So i replaced my regulator with a adjustable bbk. To no avail. however i blew the front seal then i found out my oil is full of gas not just a little ALOT. WHEre do i go from here. I need to figure out the fuel problem i just picked up a new motor vs rebuilding this 305. I asked questions about this swap in a different thread under TPI please leave any suggestions. THanks?????
Old May 10, 2009 | 09:23 PM
the gtaman's Avatar
Car: 1989 firebird gta
Engine: sbc 355 hsr 280xfi 58mm tb
Transmission: raptor 700r-4, 2800 stall
Re: i think my engines flooding out
hi did you ever figure out the flooding problem,cause mine is doing the same exact thing ?
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
