intake torq spec and seqence
Old Oct 9, 2008 | 01:08 PM
Jesse's87Z28's Avatar
does anyone know if i have to torq my tpi intakedown what are the specs and does anyoneone know the torq pattern?
Old Oct 9, 2008 | 04:10 PM
irocz28boy's Avatar
Car: 2000 Z28
Axle/Gears: 10 bolt 4.10s
Re: intake torq spec and seqence
IIRC, its about 25 lbs of torque, but I don't remember the sequence. I think it's in the Haynes manual, though.
Old Oct 9, 2008 | 04:43 PM
george 88gta's Avatar
"Apply silicone sealer to intake manifold bolts and torque bolts to manufacturer�s specifications. Before installing base check alignment of rear machined surface with block mating surface. Make sure they align or replace manifold. Follow this bolt sequence, as the Helm has mistakes in some years:
12-11-4-1-5-6 front of intake
10-9-3-2-7-8 front of intake" Found this sequernce in the Super ram intake install info. The 1988 shop manual states 25 - 45 ft lbs for a TPI intake. #1 is on the thermostat (drivers side) of the intake.
Old Oct 9, 2008 | 11:25 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
The fundamental idea is to start in the middle of the intake, working across to each side, and working rearward and forward. Any sequence that follows this logic will work great. I have always used 30 ft-lbf and silicone the threads.
In order to prevent oil leaks, clean the china walls very well. I always use the cork fillers along with silicone sealant. Be sure to get a bit more silicone into the corner where the block, intake and heads meet. Also, use a smear of silicone on both sides of the intake gaskets around the coolant passages. (Just a smear with the finger tip)
Old Oct 10, 2008 | 08:28 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Doc gotcha, but I'd use 35-40 ft/lbs, but I'm a weenie
Alsi, especially tru for the inner holes (but I do it on all of them) is to dip the bolts n the liquid teflon stuff to keep the oil and anti freeze seeping up into the intake.
db057
Apr 28, 2019 07:45 AM
Jorlain
Oct 8, 2015 01:57 AM
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
Formula_88AE
Sep 3, 2015 01:47 PM
