Good heads for L98??
Old Oct 15, 2008 | 10:47 PM
89irocdrew's Avatar
Car: 89 355 Iroc Camaro
Engine: 355 TPI
I have a 89 IROC with the 350 TPI it has been rebuilt and bored .30 over and i was wanting to put some good heads on it. I was wondering what you guys think are a good set for these engines? Or Should i have the stock ones ported,polished and bigger valves set it? The car will be a sort of daily drive with headers, Eldebrock intake manifold runners, bigger TB, And wanting to do a LT4 Hot Cam in it also. Let me know what you guys think, Thanx..
Old Oct 15, 2008 | 10:54 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Good heads for L98??
Would you be porting them yourself, or no?
Old Oct 15, 2008 | 11:24 PM
89irocdrew's Avatar
Engine: 355 TPI
no my buddy does engine building and porting and polishing as a side job.
Old Oct 15, 2008 | 11:28 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Unless he's giving you a great deal it might not be worth it. Porting is labour intensive and paying someone to do it can get expensive quick.
Old Oct 15, 2008 | 11:36 PM
89irocdrew's Avatar
Engine: 355 TPI
well he will give me a deal but like you said he will still be spending alot of time on it so it will still cost me some bucks. What are some good aftermarket heads? i think i saw some in a car craft mag that said 80hp iver stock L98. I think they were eldebroc also. any ideas?
Old Oct 15, 2008 | 11:52 PM
89irocdrew's Avatar
Engine: 355 TPI
ok i have search on here a little bit and the AFR Eliminator 195's seem to look good to me. And the have recently updated them with ls1 style lightweight valvetrain. They say it is 30hp over the old style ones. Think these will do good with that setup?
Old Oct 16, 2008 | 03:48 PM
Rob Wade's Avatar
Car: 89 jaguar xjs convertable
Engine: 89 L98 5.7 TPI
Axle/Gears: 3.23 dana 44
I run the TFS 175 cc aluminum heads on my 89 TPI motor. They are basically a corvette aluminum head with a 2cc smaller combustion chamber. Decent head with garbage for valve springs, but then for $1000.00 new out of the box, I got what I paid for!
CRFred
Feb 7, 2016 11:39 PM
NBrehm
Aug 25, 2015 11:49 PM
NinjaNife
Aug 23, 2015 11:49 AM
matthew911
Aug 12, 2015 09:38 AM
anesthes
Aug 8, 2015 09:37 PM
