Comp XR276HR-12 and idle vacumm
Old Oct 16, 2008 | 10:13 PM
BA68SS's Avatar
I have this cam with a vortec head setup and 52mm Tb.The car is very rich at idle. I have adjusted minimum air and TPS with no effect to the issue.I checked vacuum at idle today and it is at 9.5 to 10." I'm sure this is the cause of the rich idle. Is this normal with this cam?I have checked for vacumm leaks with no luck. What do you think?
Old Oct 17, 2008 | 10:12 AM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Re: Comp XR276HR-12 and idle vacumm
Originally Posted by BA68SS
I have this cam with a vortec head setup and 52mm Tb.The car is very rich at idle. I have adjusted minimum air and TPS with no effect to the issue.I checked vacumm at idle today and it is at 9.5 to 10." I'm sure this is the cause of the rich idle. Is this normal with this cam?I have checked for vacumm leaks with no luck. What do you think?
Has the car been tuned?
Old Oct 17, 2008 | 03:11 PM
BA68SS's Avatar
Brand new build and just started all the mechanical tuning before having a chip burned. As far as timing , air,tps etc. yes its tuned. has stock chip now.
Old Oct 17, 2008 | 08:22 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
It's gonna take some PROM tuning to get your A/FR's dialed in with that cam. I've got several hours of tuning in my setup using that cam.
With the stock chip, your eyes will probably be watering everytime you start the car from running too rich.
You'll also need a higher stall or a manual tranny with that cam.
Old Oct 17, 2008 | 08:43 PM
BA68SS's Avatar
Thanks 1bad91z. I have a 2500 precision industries convertor. I spoke with Streat and Performance and they told me I had to get my vacuum up to around 15"to 13" minimum before proper chip tuning.They also said they thought this cam would hold alot better vacuum than I have. I notice you have the same setup as me. have you checked your vacuum? And you are correct it will water you eyes in no time.
Old Oct 18, 2008 | 10:01 PM
YenkoST's Avatar
Car: '90 C1500
Engine: SBC MPFI
Transmission: 4L80e
Axle/Gears: 4.30
Your vacuum will increase once its tuned. But defiantely start on that process.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Jorlain
Oct 8, 2015 01:57 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
