why wont me car turn over
Old Oct 20, 2008 | 08:23 PM
1986350's Avatar
Car: 1985 Pontiac trans am
Engine: 350 4bbl
Transmission: 5-Speed
Axle/Gears: limited slip
Hi i have a 1986 trans am and the fuel pump seemed like it was going. But now it wont kick at all. So then we replaced the fuel pump relay. But now it wont start at all it has a full tank and it turn over at all. It seems like it is trying but its not doing anything. The runs for 2 or 3 seconds and no to change the fuel pump we have the cut the flowmaster off and and drop the tank and then put it in and then weld the muffler back on. Any help would be great. i got a new job and it requires me to drive ALOT so i need to get this fixed ASAP
Old Oct 21, 2008 | 11:36 AM
Nater36's Avatar
Car: 1989 Firebird Formula
Engine: 310 HSR, TFS heads, zz4 cam
Axle/Gears: 9 bolt 3:70
Re: why wont me car turn over
first of all be sure its the fuel pump... can you hear it at all when you turn your key to the on position?
if your sure its your fuel pump there is a way around dropping the tank but is very dangerous incase of a car wreck.. you can cut a trap door underneath the carpet right behind your backseat and easily access the fuel pump. do a search for this and get step by step instructions
Steven 86IROC-Z
May 24, 2026 04:52 AM
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Fronzizzle
Aug 9, 2015 01:15 PM
