External Fuel Pump, Return Question
Old Oct 24, 2008 | 12:30 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
I'm planning to install an external FP on my TPI install ( Cost and availability of tank and in-tank sender is too high). One of the books I got on TPI install suggested using a pump from a 1980 280Z, Airtex # 8312. The reasoning was that the return could be "Tee'd" into the pump on the tank side, rather than running it to the tank itself.
While this sounds interesting, I would like to hear your thoughts on it.
Also, if anyone has experience with an external pump I would like to hear about it ( noise, performance, etc)
FYI, the vehicle is an '85 El Camino w/ L69 engine from '87 MCSS.
Old Oct 26, 2008 | 06:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: External Fuel Pump, Return Question
I don't see why not , however I like the idea of returning fuel to tank so as to lose some of the heat picked up when passed through the engine bay
Old Oct 26, 2008 | 08:59 AM
1bad66ss's Avatar
Car: 66 Chevy II SS/89 iroc
Engine: 355/305
Transmission: 350 Turbo/T5
Axle/Gears: 3.08 posi
There's a guy on team Chevelle, who is running these two pumps; one's a low pressure and the other high.
AC Delco #EP42S is GM #6472382
AC Delco #EP184 is GM #25115528
So I wonder if the single Airtex # 8312 would work good?
Frozer!!!
Jan 19, 2024 04:55 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
Kaweh
Aug 9, 2015 02:54 PM
